SERVER A - Windows Server 2003 32 Bit IIS6.0
SERVER B - Our DB Server is on a separate computer running Windows Server 2008 64 Bit MS SQL 2008 R2 64 Bit
PHP 5.3.10 Build Date Feb 2 2012 20:26:31 Compiler MSVC9 (Visual C++ 2008) Fast CGI (Non Threaded Safe)
[PHP_SQLSRV_53_NTS_VC9]
extension=php_sqlsrv_53_nts_vc9.dll
[PHP_PDO_SQLSRV_53_NTS_VC9]
extension=php_pdo_sqlsrv_53_nts_vc9. dll
<?php
$serverName = 'DBSERVER';
$connParams = array('UID'=>'UID', 'PWD'=>'PASSWORD', 'Database'=>'DATABASENAME','ReturnDatesAsStrings'=> true);
$conn = sqlsrv_connect($serverName, $connParams);
if(!$conn){
$errors = sqlsrv_errors();
die(var_dump($errors));
sqlsrv_connect($conn);
die('connected');
> array(2) { [0]=> array(6) { [0]=> string(5) "IMSSP" ["SQLSTATE"]=>
> string(5) "IMSSP" [1]=> int(-49) ["code"]=> int(-49) [2]=> string(390)
> "This extension requires either the Microsoft SQL Server 2008 Native
> Client (SP1 or later) or the Microsoft SQL Server 2008 R2 Native
> Client ODBC Driver to communicate with SQL Server. Neither of those
> ODBC Drivers are currently installed. Access the following URL to
> download the Microsoft SQL Server 2008 R2 Native Client ODBC driver
> for x86: http://go.microsoft.com/fwlink/?LinkId=163712" ["message"]=>
> string(390) "This extension requires either the Microsoft SQL Server
> 2008 Native Client (SP1 or later) or the Microsoft SQL Server 2008 R2
> Native Client ODBC Driver to communicate with SQL Server. Neither of
> those ODBC Drivers are currently installed. Access the following URL
> to download the Microsoft SQL Server 2008 R2 Native Client ODBC driver
> for x86: http://go.microsoft.com/fwlink/?LinkId=163712" } [1]=>
> array(6) { [0]=> string(5) "IM002" ["SQLSTATE"]=> string(5) "IM002"
> [1]=> int(0) ["code"]=> int(0) [2]=> string(91) "[Microsoft][ODBC
> Driver Manager] Data source name not found and no default driver
> specified" ["message"]=> string(91) "[Microsoft][ODBC Driver Manager]
> Data source name not found and no default driver specified" } }
SQLNCLI10.DLL 2009.100.1600.1
SQLSRV32.DLL 2000.85.1117.0 (I Updated this one with the DLL from another server but still didn't help) It is now Version 6.1.7600.16385
HKLM\Software\ODBC\ODBCINST.INI\SQL Native Client 10.0
