How to investigate and fix system startup problems using Paragon Rescue Kit Free
Posted on
5,343 Points
3 Endorsements
Last Modified:
Published
Experience Level: Beginner
5:13
In this Micro Tutorial viewers will learn how to use Boot Corrector from Paragon Rescue Kit Free to identify and fix the boot problems of Windows 7/8/2012R2 etc. As an example is used Windows 2012R2 which lost its active partition flag (often happens during backup restore or disk swap or wrong installation)
Author:noxcho
0 Comments
Natural disasters, technical faults, human error—these are just a few factors that leave your IT systems vulnerable to failure. To ensure incidents like these don’t catch you off guard or put your team offline, emergency planning is a must.
Post purchasing a portable SSD recently, I ran into several performance issues. Namely, the new SSD (SanDisk Xtreme Pro 1TB) having slow speeds on data copy and the files (on disk) taking a lot of disk space. These issues are now sorted but I want t…
